Once the temp gets below 32 my driver side, and only driver side, wont close. I have to put my arm out the window in order to close the door so the car will go into gear. Once i start driving the door will close but will not open from the inside (or outside) and I have to leave via the passenger side door. Once the temp get above 32 or so everything works fine. The door actuator was replaced due to broken plastic pieces inside, but the problem still persists. HELP!!!
