5Post/
F10
BMW 5-Series Forum
1.3KVIEWS
1REPLIES
0APPRECIATES
06-25-2025LAST POST
Hey guys had a question? I have a 2014 550i xdrive the issue I’m having is a battery discharge code that pops up when I wash the car or after a heavy rainstorm. I’ve seen threads about the driver door handle which I’ve already replaced and the shark fin seal which I’ve also replaced and was wondering if someone had other issues or if yall could lead me in the right direction!
hmm interesting have you checked the terminals make sure its nice and tight. also check the bottom of the vehicle because like my 2011 550 the negative and positive run through the bottom of car on right passenger side and starter is right there as well bottom of crankshaft and above plastic cover. look for anything suspicious.
Another spot to look at is passenger side under the hood above wheel suspension, will be black plastic cover remove that a sensor or plastic plug might be holding it with t-20s, but their will be a small red terminal there
